Grazer
- Joined
- Dec 16, 2011
- Messages
- 183
- Reaction score
- 0
- C Dory Year
- 2004
- C Dory Model
- 22 Cruiser
- Vessel Name
- C-Horse
I just pulled my rod holders off the forward face of the splashwell to clean and check for damaged core. I was pleasantly surprised to see that the holes are drilled through solid glass. Is there any technique to putting things back? Should you epoxy seal the edge of the holes before re-installing the hardware? Or would it be better to in-large the hole slightly, clean with acetone, fill the void with thickened epoxy (cabosil and chop strand), then redrill hole through annulus of epoxy and fasten with through bolt. Any suggestions are always appreciated.
Grazer
Grazer
