Christopher-Robyn
- Joined
- Jan 10, 2008
- Messages
- 80
- Reaction score
- 0
- C Dory Year
- 2008
- C Dory Model
- user_field_choice.c_dory_model_16_Angler
- Hull Identification Number
- CD016709D808
- Vessel Name
- Christopher K.
Any "voice of experience" advice/tips from you veterans out there on the following?
1. Is there a "better" way for an old guy to refill each 6 gallon portable fuel tank on a 16' C-Dory? The factory manual says to remove them from under the engine well & fill them on the ground. Lifting a full (30+ Lbs ?) fuel tank from the ground back onto the trailered boat & then putting it back under the engine well each time is not my idea of fun. Or should I just "man-up", do the lifting & stop whining?
2. What is the safest/cleanest way to transfer fuel from a container into the fuel tank without spillage? "Spill-Proof" container, syphon hose, etc.?
Any help based on your experience will be greatly appreciated! Thanks!
Paul K
Paul K
