I like to remove all the fuel possible from the Mary Ellen before storing her for the winter. I have tried various methods to drain the two 25 gallon tanks. I purchased a spare hose with a pumping ball a couple of years ago. I put one end of the hose down thru the fill tube and hold a 5 gallon tank at a height above the tanks and with a little pumping I usually can get a flow going. Then I put the can on the shop floor until it is full. I have to adjust the hose to maintain flow several times. This year I purchased an extra female end from Honda that fit on the hose and would plug into the 25 gallon factory tank fitting. I just completed emptying the tanks today and I have to say it worked better than anything I have tried before. I was able to get just about all the gas out in short order. It was a much cleaner operation with the hose plugged into the factory tanks without pulling the hose in and out of the fill tubes.
