Hello,
My 19 Angler is powered by a 75 Yamaha 4 stroke. Also have a Suzuki 15 trolling motor. I find my 19 Angler is a little underpowered with the 75....especially when I carry 3/4 full fuel tanks for longer trips. As well as the additional weight carried in the stern from downriggers, big cooler etc...At slower cruise speeds , a considerable amount of trim tabs is required...at higher speeds , not so much.I cruise at approx. 16 mph at 4300 rpm. If I go to higher rpms it feels and sounds like the engine is "working " .
I see the 19 is rated for max 100 hp...is the rating based on hp or transom weight...or both ? I was thinking of repowering with a 115 hp....as the new engines are considerably lighter than some older models.....and then use a prop designed for initial power rather than top speed.....top speed is not an issue as my cdory pounds quite a bit in anything more than a small chop, ...
Any thoughts or suggestions would be appreciated. Thanks
