RinseKit
Well-known member
Oct 27, 2012
3,789
111
2008
22 Cruiser
SoBELLE
Saw this in a marine supply store. Looks like an interesting idea. Problem would be refilling it if you don't have access to a pressurized water system.
On a sunny day the black color might heat the water sufficiently for at least a warm wash/shower.
http://www.rinsekit.com/
Some folks around here use 2 gallon sprayersat boat ramps that don't have spigots.
Mainly a quick rinsing of the hubs. Most guides I see immediately spray their trailers immediately after launching..
Not as fancy, but gets the job done.
This appears to "store" the pressure from the water mains. At this time no way to pressurize the container, except with water pressure. I suspect that the pressure will diminish as you get to the end of the water in the container. They mention in FAQ that in the future there may be a bicycle pump adaptor for the kit, so you can pressurize it.
I have a 5 gallon sun shower, which has a foot pump, and can be filled anywhere. It also rolls up and stows in a small space. The product mentioned does not collapse, and will take up the space full or empty.
