side window weatherstripping
Well-known member
Oct 27, 2012
3,717
59
2008
22 Cruiser
SoBELLE
On my CD 22 one of the side windows has the weatherstripping coming loose. The loose piece is attached to the outer sliding pane and faces inside to the non moving pane. The piece is attached to a channel in the metal piece at the after end of the glass pane.
I have tried removing the pane by lifting it up like is done to get the sliding screen out. This doesn't work. I tried to get the entire window out by removing all the screws. It appears that the screws just hold the interior metal trim piece on.
Does anyone know how to get the window apart so I can reattach the weather stripping?
Thanks.
Never mind. I figured it out. Remove the black rubber strip around the non moving pane. Now that pane can be slid forward to allow access to the inside of the moving pane where the interpane weather stripping is attached.
Duplicate post.
