Greetings.
1. It's been 4 years, time to service the water pumps on both outboards (Honda 135 and 8HP kicker, both <200 total hrs.). When this is done, is just the impeller replaced, or is it best practice to replace the entire pump, or some other degree of additional maintenance beyond the rubber impeller itself?
2. Neglected maintenance last year to a shameful degree. I'm additionally planning to have the dealer perform the following: a. Oil and filters both engines. b. lower unit gear oil both engines. c. all internal fuel filters both engines. d. Replace main Racor spin-on filter and bowl and provide a spare. e. Replace all internal and external sacrificial anodes on both motors. f. Remove both props to the thrust bearings, inspect, grease spline shafts, reinstall with new pins. g. grease all Zerk fittings both engines, plus any additional recommended engine cable or other lubrication. h. Charge both batteries + visual inspection of electrical system.
Does this seem reasonable and sufficient to you guys? Have I forgotten something?
3. Last time out (boat had sat unstarted >3 months) main motor started up and initially ran fine, but began to stumble/miss when above about 4,100 RPM. Shut down, re-started, and it ran fine (~ 8 mile run to our cabin) when kept under 4,000 rpm, all on calm seas. On the return trip same thing happened: ran fine up to and at 3,900 RPM, but began to stumble during a test burst to 4500 RPM, then would only run smoothly at displacement speeds. With it and the kicker in tandem we got home fine. Seemed like classic fuel-related issues, but little to no water was visible in Racor drain bowl. Between the 2 runs, I added one can of Seafoam to ~20 gal. existing fuel in the tank, and I routinely use Sta-Bil marine in any fuel added to the boat. Any ideas? I understand I've set myself up for "ideas" involving better boat maintenance
Thanks in advance for your ideas and suggestions.
Mike
Mike
