Ashley Lynn
- Joined
- Apr 22, 2007
- Messages
- 256
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 22 Cruiser
- Vessel Name
- Ashley Lynn
I have an intermittent problem--now more often than not. The start battery (battery #1) will not start the boat, nor will it operate the trim on the motor. However, battery #1 still can power everything else (electronics, etc)..so, I don't think the problem is with the #1 battery.
I have a perko switch (Off, 1, All, 2). I have checked the #1 battery connections and the connections on the switch and they are tight and no corrosion. The motor will start on #2 and all. It will not on #1 (13.3volts read across #1 battery and 13.5 volts across #2 battery).
Any suggestion as to were I should look next?
Thanks in advance.
Thanks in advance.
