MOOSE
Member
- Joined
- Nov 7, 2003
- Messages
- 627
- Reaction score
- 1
- C Dory Year
- 2001
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- CD022963D101
- Vessel Name
- MOOSE
My boat has twin 1999 Honda BF40s. Earlier this spring, the port engine tachometer failed, or nearly so, jumping around a bit upon start-up, but then showing no indication of rpm. Thinking the tach was faulty, and not knowing what else to do, I replaced the gauge but there was no change. Then recently, while at cruising speed, I noticed that the port engine was charging at only about 13 volts while the starboard engine was more properly at 14.8. And then yesterday, for whatever reason, the port engine was also putting out 14.8 volts and the tachometer was working fine!
I don’t know how these two circumstances are connected, but they appear to be. And I can even vaguely understand how something in the port engine charging circuitry may have failed such that it was putting out only 13 volts. But what would explain a spontaneous recovery?
All was fine as of yesterday, but I need to understand what is going on for when and if it happens again. Any clue?
Al
Al
