SounderSolutions
So here's the question. 2005 tomcat 24 has a fuel capacity of what?
Written on the bulkhead by one tank it says 68 gals. So i assume thats 68 gals per side. I took a trip which ended up being 98 nm round trip and the fuel gauge needles pegged on empty. Aside from the pucker factor of making it to port, my simple math tells me I'm looking at 1.4nm/gal at 4800rpm. I am not impressed.
So off to the gas station to I go expecting a 60ish gallon per side fillup. The pump kicks off at 23gallons and I end up topping off at 25. Now I'm at 3.92nm/gal on a side(much better) and a huge question of how big are my tanks?? Is there any such thing as an accurate sending unit or fuel gauge?
Anyone out there with a same model year and size Tomcat mind sharing your tank size? Knowing will help set the DTE on my electronics and provide some better piece of mind.
Thanks in advance!
Thanks in advance!
