nordicstallion
- Joined
- Dec 16, 2007
- Messages
- 380
- Reaction score
- 0
- C Dory Year
- 2004
- C Dory Model
- 19 Angler
- Vessel Name
- Rylee Rose
The more I work on the new/used boat the more dissappointed I become with human nature.Advertised as WELL MAINTAINED,should have been NEVER MAINTAINED. Upon our return from our maiden voyage,the little woman heard a grinding sound in stb. brake drum.I wondered about the large amount of grease the wheels took when i greased them. Pulled the grease cap.Found the bearings to be loose.Pulled the drum,found a very well worn bolt that had been laying loose in the drum for a long time. The bolt didnt match the other backing plate ,thin headed bolts ,but one was missing. Next ,I found that the remaining bolts are not tight & there is play in the backing plate. This stuff goes right along with the prop banging around like a bb in a boxcar instead of torqued to 40 lbs,the meathead NEVER used a transom saver,NEVER changed gear oil & pretty much ignored everything except Bodega Bay salmon & halibut. This is the tip of the iceberg Im afraid.I may not be ready for tuna this year as everything is suspect. Ill have to check every screw that penetrates the core as I dont know what he did or had done.The boat is an 04 & motor has only 110 hrs & sonar water mileage says 675 mi.& was stored covered.Lucky for me he didnt have more time to completly destroy it and lucky for him he found a buyer who still had a little faith left in his fellow man, but its another brick in the wall. I know,I know,buyer beware,but there should be room for seller beware or perhaps just a little honesty!!Vern/C-Dog
