to boot or not to boot.....
dotnmarty
Active member
Nov 3, 2003
4,209
1993
user_field_choice.c_dory_model_16_Angler
Hull Identification Number
DOR15295C393
LIZZIE II
I recently went from dialup to DSL. Should I shut the computer down after each usage or just leave it on? Thanks.
You should first make sure that you have ALL the software updates installed. If you just switch over from dial up, you're probably many patches behind. After that, it dosn't really matter is you leave it on or off.
Roger is right that if you leave it on and have automatic update selected, you will get a lot of updates to begin with.
Turning computers on and off has been the subject of a lot of debate. There are proponents on both sides of the issue.
Personally, we have had a cable connection for a long time and I tend to leave my computer on for days at a time. The darn things take so long to boot up with firewalls and antivirus software, etc, etc that I don't have the patience to wait for it. I would leave it on permanently but I've noticed that my computer's performance begins to degrade after a few days if it is not allowed to go through it's shutdown routine. I used to run Ad-Aware and a spy finder program that cleaned out the temporary files and cookies then restart once a week after Norton Anti-Virus did it's weekly thing but recently switched to twice a week because of all the tracking cookies that one acquires these days.
More than you wanted to know.... Actually - it becomes your choice.
You will also want to enable the firewall if your DSL modem does not have
one built in.
If you do not have a firewall in XP, then perhaps you are running XP/Home.
Once you finish the upgrade to SP2, then I think a firewall is available.
I haven't worked with XP/Home too often.
Mike
