I know its traditional to taper the knot that connects anchor line to chain for use w windlass. Grog's knots didn't think it was so necessary as in the past- and it seems my windlass will pull in the line without the taper [I did about 8-9 turns vs 5-6 ] to see how it would work. I can always go back and trim some off.
Here is the quote from Grog's Knots
Tapering the tails: It used to be fashionable to gradually thin the strands for an additional few tucks. In tarred hemp this made a very elegant tapered splice. Modern rope is sufficiently slippery to mean that the tapered tails tend to get dislodged and make the splice look very untidy. True tapering of individual strands is rarely done now and should probably never be attempted by amateur, occasional, splicers.
Alternative Taper: After sufficent tucks have been made for strength, cut and burn one stand and then continue the splice with remaining two strands. Cut and burn one more and splice the remaining strand before cutting and burning it too -
Any suggestions - I am inclined to do the alternative taper . Should I whip the final end or use the whipping glue.
Thanks - and thanks to the forum for great information on Windlass choice -
