Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,963
- Reaction score
- 298
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
Sea Duck,
The current incarnation of the navman is the NORTHSTAR F210.
The Lowrance can be used with either a 2" or 4" display: LMF 200 or 400 (2" or 4") plus the E P 10 fuel flow (also EP 20 tank guage level, if desired. The guages will read all sorts of information: NMEA 2000 data: paddlewheel speed, GPS speed, tachometer, battery voltage, alternator voltage, engine temperature, water pressure, engine oil pressure, fuel pressure, boost pressure, transmission oil pressure, atmospheric pressure, temperature, depth, engine loads, engine hours, fuel flow, fuel economy, fuel remaining, fuel used, fuel range, trip fuel used, seasonal fuel used, engine synchronizer, fluid level, GPS position, trim tab position, engine trim position, and engine alarms and of showing data in the following page formats: single digital, dual digital, quad digital, single analog, dual analog, quad analog, trim tab, engine diagnostics, engine trim, and engine without a Fuel Flow E.P. with an array of electronic probes, including fluid level, temp, speed,
