Towing a 22' C-Dory Cruiser with 5000lb capacity
Tiderace
Jun 19, 2026
2
Location
Seattle
How realistic is it to tow a 22' C-dory Cruiser with an AWD vehicle that has a towing capability of 5,000lbs? I am not looking to tow over mountain passes or cross-country. As this will be my primary vehicle, I want something that still gets decent gas mileage when I am not towing. I don't want a pick-up or a gargantuan SUV. Please no uninformed opinions, I need feedback from people that have some experience in this.
thx!
I tow mine with a 4Runner without issue, but having towed boats across the country, I might want something more-suited to the task if there were mountains involved.
This has been addressed many times in the past. Highly recommend the search tool. (Not saying this snarkily, but the answer is there for you now.)
Depends on what the weight of your boat and trailer is. If it is under 5K# it shouldn't be a problem. My CD22 on an aluminum trailer weighs 4400# with typical contents onboard. I tow it with a R51 Nissan Pathfinder. The Pathfinder tows it fine, but the gas mileage is around 20mpg without the boat (~13 with it).
Whatever vehicle you get, you might want to put air bags in the rear suspension. I find these help the ride a lot when towing.
I tow mine all over with a 2008 Toyota 4 Runner. Does a good job. A little squirrely when a big rig passes on the freeway. I do not tow above 65mph. Want to make sure not to blow a wheel bering by towing too fast. I tow the C-Handler up pretty good sized hills in WA. The 4 liter engine can actually pick up speed if you want to put the gas pedal thru the floor.
Maybe in the distance future I might upgrade to a 1500 class tow rig. For now the 4-Runner is doing a great job.
Tight lines,
Thanks!! You mentioned having the 4l engine... that's the V6 model rated up to 5000lbs. This is great... a definitive answer! You mentioned being in WA. Same here. My towing would be maybe a dozen times per year, limited primarily to the I-5 corridor between Olympia and Bellingham. With caution, care and an understanding of the limitations, seems like a 5K tow vehicle would be 'adequate'.
Apologies all if this is a tired old topic. I am new here.
That should be no problem with the V6 4 liter engine. I live in SW WA and tow to Astoria and points west. Mainly fish the Columbia River and the Ocean at Ilwaco.
I sure love my C-Dory. I just retired so I get to spend much more time on the C-Handler then the typical Saturday combat fishathon on the rivers around Portland and Vancouver.
Tight lines,
I tow my 22' cruiser with a 2007 Honda Ridgeline that has a 5000 lb capacity, and have not had any problems with it. Mileage sucks (11 mpg) when towing. I estimate my towing weight (boat + trailer) is about 4400 lbs.
I tow my 2012 dory with my jeep unlimited all along the east coast, in usa it IS over weight, in every other country on earth, it is 600 lbs under weight. I do tow the boat through mountains/elevations with my 6.2 chevy.
When I had the CD 22, a Jeep Grand Cherokee towed it easily all over the place. Another Jeep Grand Cherokee even towed the CD 25 a couple times. One of the trips with the CD 25 was a few hundred miles up to Coronet Bay, WA. That trip made me a mite nervous so on the way back I traded the Jeep in on a Dodge 3500 diesel.
One thing to keep in mind is what your vehicle towing specs say about the max capacities. It may state that above a certain weight a weight distributing hitch is required. Both my Jeeps called for one to tow the top 6500 pounds but I never used the fancy hitch and didn't feel I needed it. However, even though you won't really need it for your infrequent and short tows, if it is specified in the owners manual and you have trouble when not using a WD hitch there may be some liability complications with your insurance. Thinking about that had a lot to do with my being nervous towing the big boat with the little rig on I-5 even if the Jeep didn't seem to be bothered by it.
No such thing here! I tried the search with your specific info and got a whole bunch of possible returns but it would take a while to sort through them so you did good asking. If you are bored you can search for threads containing info on towing with your exact vehicle that might help lessen your worries.
I can't help you as we have dully crew cabs .
His and hers. LOL
Yes my wife has a Ford Dully crew about that she actually found and bought.
Keep in mind the simple physics of towing. Any vehicle can put into motion the combined weight of the tow vehicle and boat on the trailer. Not every vehicle can safely stop or slow the combined load in a reasonable distance. The published specifications in the vehicle owners manual assume perfect trailer and vehicle brakes. Typically boat trailer brakes are less than perfect, especially if ever exposed to salt water. I towed our Cdory 22 with a 2500 Silverado with the Duramax and Allison transmission and regularly maintained the trailer brakes. Even so, it was uncomfortable towing on the interstate, especially in heavy stop and go traffic. I also experienced panic stops to avoid deer and livestock on the road, not always successfully. My theory is to use the largest and most capable tow vehicle practical for you, and then limit your exposure as much as possible. Ken
my 22 with a tandem axle galvanized trailer is right about 5000 lbs. it has twin motors and I feel like it is heavier than most 22s
Hi Clay,
How is the Merlin progression?
Just added a Maxwell Free Fall windlass to mine.
Tight lines,
