B~C
Active member
- Joined
- Oct 31, 2003
- Messages
- 2,873
- Reaction score
- 0
- C Dory Year
- 1999
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- 860
- Vessel Name
- Blue~C
Edited by Da Nag - Original MSN Poster":caox3o0e said:From: CAVU (Original Message) Sent: 11/1/2003 6:20 PM
I had new brakes put on my 6 year old trailer at a local shop in June this year. Yesterday I took the hubs off to inspect the bearings only to find that the rear seal had blown and put a lot of grease on the new left brake (drums). I know the book says you should change the brake. My question is: has anyone ever attempted to clean the brakes in a case such as this? I really hate to buy another new brake.
To answer a question on the old tech site regarding contaminated trailer brake shoes.......
...if braking friction material has been contaminated with grease or oil you can clean the surface of the material with an aerosol brake cleaner from the local parts house. This cleaning, often times, will only provide a temporary fix as the oils that have soaked into the material will resurface when the brakes heat up. If the material isn't to mucked up, I'd give the cleaner a try
