Matt Gurnsey":1hu6xqc7 said:
King trailers uses material that is a polypropylene that wraps around the entire 2 x 6 and works well. This one of the reasons we like the Kings because the Slick Bunk material works so well.
This is not to be confused with the pads that some others offer either as factory addition or aftermarket. The slick bunk material is sold in lengths and goes on as single piece by sliding over the bade 2x6.
My 2 cents and worth what you paid for it.
Thanks for all the replies and ideas.
I'll try to work my way thru them here.
The slick plastic doesn't seem to work as well with bottom paint on the boat. The bottom paint has a rough feel to it rather than the slickness of gelcoat. (Can anyone else concur on this?) We put the slick plastics on our most forward bunks, but the front sponsons on the TC24 change angles as you move thru the first few feet of the boat. The irregular bottom causes the bunks to contact in different areas at different angles until the boat has settled into it's resting place on the trailer bunks, thus even the slick plastic can work paint off and the plastic surface has even been roughed up some by the boat. So I'm not sure this is the best solution for my boat with bottom paint, but we've tried some of it.
We recarpeted our bunks last year with the stuff from Cabela's. Worked great. Give 'em a try.
Rick & Donna
I've looked at Cabela's "bunk carpet" before, but they don't sell any bunk carpet wider than 12" which is too narrow for my 2x6's
BUT tonight I looked thru their website at just standard marine carpet and saw the BEST selection I've seen so far. I will probably order some of the premium marine carpet to replace on these bunks.
John,
I had the same problems with the design of my Pacific Trailer for my Tomcat. Check out my photos under Trailer Modifications to see how I resolved my problem. Without a doubt, use Slick Bunks on the front 1/3 end of your trailer instead of carpet. I like this product because it attaches to your bunks on the sides, negating the possibility of scratching your gelcoat if the screws were to back out.
Also, I suspect the scratches on your gelcoat may be occurring during retrieval at the launch ramp when the edge of your sponsons can easily hit your cross bar between your bunks because the trailer is at an angle while your boat is coming in level with water line.
Bad Boy, I checked out your photos and got some ideas. The design of the TC24 is quite different in that the most forward part of the the hull protrudes deeper than the rest of the hull. compared to the TC25. What I think I will do after seeing your photos is bring my front bunks in much closer to make a tighter Vee. This will require bracket drilling. WE WERE having the problem you mentioned of the bottom of the boat contacting the trailer and EZ Loader sent me some 2x6 with slicks to lay flat between the bunks to stop trailer u-bolts from gouging the hull. I'll post a photo. Thanks
Looking at your picture, it suggests that the bunk is not parallel to the bottom of the boat, and the edge is making contact--or it could be as the boat goes on the trailer. I always put two layers of carpet on the bunks--use monel staples.
On the Tom Cat, we use the slicks just to help loading/unloading--but make sure that maximum contact is maintained with the trailer bunks.
Bob, I thought I saw an alignment problem also. So first I loosened the bunks slightly and let them move to where ever they wanted. After I had them out of position once or twice at recovery I just tried loosening them with the boat sitting on the bunks and then tightening them back up hoping they would have found their position. It didn't work and I'm kind of baffled by it.
I like the doubling up on the carpet idea, never thought of that.
I'm confused by your last line, that you use the slicks just for loading/unloading, aren't they there all the time once installed??
Thanks everyone,
The photo above shows the flat centerboard that is EZ Loaders solution to keep the trailer from gouging the hull during recovery. After looking at this photo again I've noticed I can't move the front brackets closer because of the design of the frame. This photo is before the front bunk slicks were installed.
