trailer transport
Kingmann
Nov 22, 2016
18
2000
22 Cruiser
Eva
Planning 22' C-Dory transport on trailer from Vermont to Washington State. I have been reading about "transom savers" and would ask for input on this. The vessel has a 90HP Honda only.
I have spoken with "Smooth Haulin" out of Kansas for $1.50/mile - seems like a reasonable price.
So it looks like I will join the C-Brat family soon. I am very excited about getting on the Columbia River (aka Lake Roosevelt) just below our house in Northeast Washington.
You want some support of the motor. Transom saver is one way to do it. I have that on my Caracal cat--and it came with the boat. The only issue is that there can be some slight disconnect between the trailer and boat--vibration, going over bumps etc. I have never had any issues. Mine is on a Suzuki 140.
For all of my other boats, I have either used the MY wedge (hard rubber) which goes over the longer single lift cylinder arm between the motor and cylinder. Some use PVC pipe in there--it can scratch. and is not as strong. The MYWedge can get soft with the heat--and if too much pressure, creep down. Another option is a piece of wood between the engine bracket and support on the engine. This is probably the most commonly used "device". A 2 x 2" piece of wood--perhaps OAK? A round closet rod 1 1/4 to 1 1/2 " wooden towel is cheap.
I also like to put my engine all of the way over to one side to release any pressure on steering ram. Talk to the hauler. Is the boat going on the trailer, //road, or on a transporter? (Flat bed or boat carrier?) If on your trailer--be sure the tires are new--(less than 5 years old) that wheel bearings are in good condition, well greased. Be sure that the hauler is both licensed to haul commercially, that he is bonded and has insurance. Also be sure that your insurance is in effect and covers the boat in transport. $1.50 a mile is a decent price. The distance is about 3000 miles. If I have a boat shipped, I try and find a hauler who has taken a load near to where I want to pick up the boat, and has no scheduled return load. You might get a better price...or not.. I like to have a good coat of wax on the boat before cross country hauling. If possible have the windshield covered. My black out curtain fits on the outside and protects mine. Be sure the hauler either calls you each day or has a tracker, so you can check on the boat.
Congratulations on the purchase of a boat!
I was just up in Kettle Falls today in my c dory going after the sturgeon.
Get on the water and get fishing.
I have had 2 boats hauled from the east coast, one in cheasapeake bay the other from New Jersey. Both times using U-Ship, the last one from NJ cost $2400. I have the business card info, if your interested.
It is best to have the motor as near vertical position as possible.
I had my CD towed from W. Palm Beach, Fla to Anchorage, Ak.
THe engine should be in the vertical position as well as secured from hammering the hydraulic steering by swinging L/R all the time.
Not sure exactly what you are asking as I read the other posts, but if it helps, I trailer my CD-22 all over the place. Over 10,000 miles this year alone already. I leave my Mercury 115HP 4 Stroke EFI in the down position with pins in the bracket to help support the motor in position. I typically trailer at least 5000 miles a year, and knock on wood, have had no problems with the transom or outboard. I have about a foot or a bit more of clearance between the road and the bottom of the skag. Colby
I often tow my 22 Cruiser to the Keys and back, which is about 800 miles each way. I use a transom saver bought on Amazon, which allows the 90 HP Suzuki to be tilted up enough without placing strain on the hydraulics etc. A molded rubber bracket cradles the transom and a bungee around the transom securely holds the steering in a mid-line position. The other end of the saver is supported by the trailer. Seems rock solid and has worked well for me.
