Andrew":3a6mn3u2 said:
Could somebody out there please take a picture of the bottom of their factory floor boards or point me to a link of same. I have searched the site and can find pics of homemade ones and installed factory ones but I want to see how the factory floor boards are supported underneath. I wish to attempt to make my own and I am looking for ideas.
Thanks
Andrew
Andrew- As I remember seeing them, Charlie's description is exactly as they are, just right angle extensions in fiberglass from the flat panels down to the hull, closed, of course, for strength, at the corners. I don't remember any mid-panel supports, but that might be a consideration to think about.
When you make your own, you'll have to figure out how to form-fit your floorboards to the contours of the hull, both athwartships and stem to stern in the cockpit. This may be the hardest part of the project.
This would be easy if you had a big contour gauge, but who's got one 4-6 feet long?
So what to do?
First, I'd try to bend heavy wire to fit the floor contours, then transfer those contours to cardboard to begin to make templates.
The templates can then be fitted to the floor itself to get them to match more perfectly. First trim with scissors or knife, then sand with sand paper to get them more exact.
Fit each one, then tape them together into a single unit, then use a tight string to draw level lines across them to get a level floor, then trim.
Once that's done, the templates can be used to complete the vertical supports to the floor, however you're going to support it.
There may be a better process to do this, but this is how would approach it with my experience. I have done some work of this type on sailboats.
Hope this helps with your planning process. It would be really convenient if you could get your hands on a set of finished floorboards to use as templates!
Have fun!
Joe. :teeth :thup
