Verizon info share opt out
Done.....thanks for the heads up. I had to save changes (3) times in order to cover all the bases. I guess they figured most would only save once and think they covered everything. Love my cell phone but really don't like big brother looking over my shoulder all the time. :amgry
H :wink:
May want to check it again to be sure. There was (3) different things they scan for and each one has a (save) changes tab I had to use. I found it by going back to make sure the changes reflected in my profile.
H :wink:
Ditto, I only saw two...they are called "aggregate reports" and "demographic info for banners." What was the third one, David?
Captains Cat":2g2ny9ln said:
I only saw two places. Maybe some accounts are different?
Under Customer Privacy Settings
1. Customer propriety network settings
2. Business and Marketing Reports
3. Relevant Marketing Advertizing
And you need to click "Save My changes" for each of them.
Interesting...when I went in through the normal Verizon Wireless login, then chose Manage Privacy Settings, this is what I saw as well, but when I went in through the link in the post above, I only saw the two. Now got all three changed and saved. Weird.
Thanks Pat/David! I logged in as Pat did to my account and not with the link in the first msg. Your #1 was already disabled, probably did that from my phone earlier when I tried to hide from my GrandKids!
