VHF Radios, Antennas
Gene&Mary
Jan 10, 2005
206
2005
22 Cruiser
Hull Identification Number
CDO22279A505
Linnea
Does anyone have any recommendations on a VHF radio brand- Icom, Uniden, West Marine or ???.
How about antenna size- 8' or 4'? In the real world does the extra gain with the 8' matter or does the shorter length and convenience override any extra gain with the 8' antenna?
Does anyone have any experience with the combination VHF/AM,FM antennas?
Gene&Mary; You'll find that the radios are much alike as far as functionality goes as long as you get the bells and whistles you want.
I'd definitely go for a radio with Digital Selective Calling which usually includes the link with your GPS and the ability to transmit an emergency signal that includes your boat info and location to both the USCG and anyone with a similarly equipped radio, think it uses CH 70.
The 8' antenna has a lot more gain and as long as you put it on a "lay down" type mount which you'll probably want anyway to clear obstructions while trailering or going under low bridges, makes little mechanical difference. If you're on the fringes of coverage, it'll mean the difference between being heard and not heard.
Any combination antenna is a compromise. I'd look at the gain specifications for the VHF performance and if it's the same or close with the non-combo ones, go for it. Believe they probably come with dual feedlines which would preclude a splitter or a separate antenna for your FM receiver. Since you're not transmitting on FM, the matching characteristics on those frequencies are relatively unimiportant.
I've had all types of radios (brands) and it's much personal preference and price (look for a sale). Many of them have the innards made by the same folks (invariably offshore) so it makes little difference. Some have a loud hailer built in so you can scare the hexx :P out of the dockmaster. One piece of caution, never use a loudhailer while the first mate is on the bow trying to launch or retrieve the anchor. :smilep It makes for a testy cruise....
I've got a Uniden on Captain's Choice, a nice, compact little radio. They (almost) all run 25W on high power and have a low power (1W) position which is where you should run it unless you need the juice. There's lots of other little goodies like a mike that can change channels, radios that can scan all channels for action, or weather alert features, etc, etc. There's lots of good info on the net about usage, what the channels are for, etc. Print this one out and laminate it unless one comes with your radio.
http://wireless.fcc.gov/marine/vhfchanl.html
Good luck
A taller antenna may offer more range, but a shorter one can be better in rough seas (when you need it the most). If you have a big boat that is very stable in the water, get a high quality TALL antenna. The smaller and lighter the boat, the more it bounces around in rough seas, so you would want a high quality, but shorter, antenna. Then, in order to get better range (10 miles is usually too far for any recreational marine VHF), mount it as high as you can.
Basically, a tall antenna transmits in a kind of "disk" shape, while a shorter one transmits in a better "ball" shape, just not as far.
Here's a couple of links you might want to check out:
WestMarine
Shakespear Antennas
BoatingWorld
catfleet21
As far as radios go, this spring I will be upgrading to a DSC capable Uniden Polaris that I got for Christmas. The Polaris has all the features I wanted and it was on a pretty good clearance sale. So my old Standard Horizon will be relegated to backup status. I'll try to give an update when the water gets a little warmer.
Personally, I've always used and stuck with Icom products only because I've had great luck with their ham VHF products as well. I also prefer "Digital" brand antennas over Shakespeare but that's mainly due to the anecdotal experiences of our local Albacore chasers who are solidly behind Digital.
As far as length, the typical 8 footer has 8db worth of gain and the 4 has about 4.5db. That just means that the effective radiated power of an 8 footer is about twice that of a 4 footer. AFAIC, the average person ain't gonna really see much difference while shooting the bull with fellow Brats but those folk who really venture well out to sea might want to consider the 8 footer.
I wonder what Rana Verde Chris or Halcyon El/Bill would say. Chris has a 4 footer, El/Bill an 8 footer. They cruised Alaska together and should have a good handle on real life VHF usage on C-Dorys.
DSC? Hardly anything comes without DSC anymore. Thing is, the Coasties don't really have a system in place yet for it to do any good, but the local tight jawed fishermen on a bite are taking to calling their buddies using DSC to let 'em know where the bite is without revealing it to the unwashed masses....
I prefer ICOM...always been good stuff for hams, boats and airplanes. I think one of the most important features of the radio is audio output...the size and quality of the speaker. In the cabin under way...water noise...engine noise...you will appreciate a radio with good audio...and some of them are not good. Go listen to them before you choose. On the antenna...I had an 8 footer for a while on my current boat, but got tired of the length in the stowed position...always sticking out beyond the cabin...waiting to poke somebody in the eye...or poke a hole in my boat cover. The 4 footer stows much more nicely...lays right down along the handrail on the cabin top. And it's nearly the same height as the 8 footer mounted on the cabin side. Never noted any difference in performance. Anybody you really need to talk to will have a way tall antenna...and for any long distance you better get something that uses a satellite for an antenna. Like an EPIRB or Iridium. And speaking of Alaska...in that type of terrain...with a thousand feet of basalt on either side of you...you really need to hit the satellite to get out.
I would stay away from the combo antennas...really can't perform optimally in all those bands with one antenna.
Line of sight isn't going to vary much mounting the antenna anywhere on the boat, there's not much height available. A shorter 3dB antenna has a very wide power radiation pattern, a 6dB (or greater) has a very narrow band and will direct most of its power into the sea or sky with any angle of heel.
The C-Dory visor is an excellent mounting location. We're using a Raymarine 53 and the short whip.
detailphotos.msnw
-- Chuck
