Byrdman
- Joined
- Nov 6, 2003
- Messages
- 3,329
- Reaction score
- 0
- Vessel Name
- " ? " After Rename Ceremony
Wallas help please. The little fan UNDER the bottom of the unit, that provides the air/exaughst flow.... does ya'lls run all the time the unit is on at the same speed and or at least remain on all the time the unit is operational??
I had an issue with mine Thursday morning...right when I was warming her up....or attempting to warm her up... Smell, fog cloud outide my boat... the blinking red light and shut down. (thankfully it was 38 degrees and all of the SeaRay spring boaters were not out on the docks having their coffee and breakfast)... My old faithfull let me down for the 1st time in about 5-6 gallons of fuel burn...
1st thought was power issue, so I let the unit shut down, cool about 15 more minutes, then started the motor and ran her for about 5 minutes (again glad no body was sleeping next to me...I like to get up around 530...), attempted a restart with motor still running and lots of power... Same gig. Checked the power hook up fitting...a bit loose but it always has been, and sometimes pops off but I know just what to look for... did take off the ground wire fitting and krimped it down a bit to make sure I was getting a good ground...Can't do that on the power cord due to the plastic fitting device...bummer. On restart attempt I payed a bit more attention, and just listened better...knowing that my 1st fire up failed. The little oval shapped fan on the bottom of the unit, would come on, run a bit, completly stop for a second or two...run a bit more,,,,stop for a second or two....more smoke under the sink...no fan blowing to vent or provide air...then kick back on for about 15 seconds, and another "fire up" with a bit of a "poof" sound...(not enough air flow??), then the smell, the fog cloud, the blinking red light, and I shut her back down. Never had a problem with this wallas. But then, I never recall hearing the little oval fan shut off and on either...but, it seems it always ran while the unit was operational, not a intermitant running?? And...to top it off...guess which owners manual I could not find.... Mr. Wallas. I feel like my dog has left me.. Thoughts please.
