Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,963
- Reaction score
- 298
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
I notice that the water heater drain (valved--not the high pressure, which goes to the shower sump) in the TC 255 (and I believe in the CD 25) is plumbed thru tubing which passes out of the gunnel well above the top of the water heater. In the past, if in freezing weather, I have drained all water tanks--thru the bottom. It appears impossiable to drain this tank--except maybe with compressed air. Do folks put in non toxic antifreeze? Obiously there woud be a large dilution factor in the 6 gallon tank--
Second how does one get all of the antifreeze out of the tank at the end of the winter? (we will probably not go this route--but when we are gone for a month I don't want to leave the water heater on).
Thanks for any clues on winterizing this specfic water heater.
