OK, I need some ideas. My 2000 Honda 15 has no water from the telltale hole. It was that way when I first got it, then after a flushing and desalting it worked fine for a short while. Now it is back to no stream.
I just now removed the lower unit and looked at the impeller. It looks to be in great shape. It has a pretty good set, but the rubber is intact and supple. There is no sign of abrasion at all, and the pump liner sleeve is smooth and clean. The key is in place. Obviously (to me, anyway), the water pump itself is not the culprit. If they have a new one in stock at the Honda shop across the river, I will replace the impeller since I have it apart, but I don't think it will solve the problem.
I can blow through the telltale fitting and the hose, albeit not a great volume. Blowing through the tube from the pump to the engine is unrestricted, and there is no blockage or foreign material in the pickup screens or the pump housing and ports.
So? Thermostat? Wouldn't it allow flow through the telltale whether the thermo is open or closed?
Any help will be appreciated. I'm a millwright, not a durn marine mechanic!
Thanks.
Thanks.
