Over the last month I have been working under my boat, cleaning, scraping barnacles, checking on the trailer bunks etc. One of the more disconcerting findings is what appears to be a crack, more like an absence of gel coat, rather than a fracture resulting from a strike. It is right at the apex of the chine. Looking down from above (like from inside the hull, it would be looking down into the bottom point of the “V” where the topside makes the curve around the downward pointing edge of the chine), and recurves back up to the hull.
For most of the length (about 3 ½ feet) the “crack” is barely wide enough to get a finger nail into and about that same depth, 1/16” or so for an average. There are a couple of places where it is 3/16” wide and 1/8” deep. These are about 2” long and still right at the apex of the chine. The aft most part of the “crack” is about 3 feet forward of the transom, and it is all on the starboard chine.
Today I used a dremel and ground into the larger “crack” about 1/8th inch. It appears to be going into intact resin, maybe fiber edges. I am wondering what is in that chine? Is it solid fiberglass with glass matt and resin? Would there be a wood runner through there? Where it curves up from the point of the chine to meet the flat hull bottom is almost 1.5 inches. If that is all solid, I might be in good shape yet.
I currently have two opinions on a fix, and am wondering which way to go.
Fix #1. Grind it out the full length, about 1/8th inch deep with the dremel and fill with gelcoat resin or paste.
Fix # 2 Grind the whole chine down about 1/8th to ¼ of an inch, and then cover with resin, and glass matt or tape, and build it up for the strength.
The concern is that the gel paste would not provide structural strength needed to maintain the working edge of the chine. Fix #2 would entail considerable more material and time (and $$$) but may be the “right thing to do”. I will do that if it is what is needed. If fix #1 would not compromise the strength (and the boat does not rest on this chine on the trailer), then maybe the gel paste would be an adequate solution. It certainly would not be a cosmetic concern as none of that would be visible without crawling under the boat when it is on a trailer. Fix #2 would entail a well matched color and would be visible as the bottom ½ to 1 inch of the chine for about 3-4 feet.
This issue needs to be taken care of before I do bottom paint, yes, but I still want it done right before the bottom paint. I don’t want the bottom paint to be a cover up.
Yes I know pictures would be great, and I can take them, just not sure I can get them into the CBRATS site.
Any input would be appreciated. I have an appointment coming up with a “repair” guy on Monday, so I need to decide soon. Thanks again.
SleepyC:moon
SleepyC:moon
