Atomic_adam
Hi everyone. Took my 14' out on the water today. Noticed something that I'm sure other people have experienced and could enlighten me on.
-35hp Johnson with hydrofoil-
-cavitation plate is even with bottom of hull-
I found that at speed (28mph) that when i went to make a slow turn the boat basically rolled a bit and then decided to turn or felt like it grabbed. I also found that depending where people where sitting and trim level that the boat actually felt like the stern was coming loose and would move side to side a bit. I have driven a few different boat and this is a new experience for me. I was thinking that this is all a function of the C-dory hull design and that they are more of a cutting style hull. What sort of behaviour should i expect from my boat? Is this hull not meant to travel at that speed?
Cheers Adam
Cheers Adam
