Well-known member
- Joined
- Oct 30, 2006
- Messages
- 12,664
- Reaction score
- 29
- C Dory Year
- 2005
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- Brat # 2202
- Vessel Name
- Sleepy-C
Sea Wolf":19w3o1fi said:I've not done this myself, but a friend of mine added several 100-lb sacks of sand toward the rear of his van when he 1.) towed a heavy loaded boat, 2.) in windy conditions, 3.) or when he needed extra traction on the ramp, etc.
As long as it doesn't make the towing vehicle under powered or overloaded suspension wise, this seems like a legitimate way to "beef up" your towing vehicle.
You'd have to do some experimentation with different amounts of added weights to get it right for each tow vehicle and towed vehicle combination.
Worth a a try, at least. (IMHO)
Joe. :teeth :thup
Joe, That is a good option and I have used that a few times. One thing to note, If you are adding weight (like that), smaller sacks are easier to move (50#) AND they should be placed forward of the rear axle in the towing vehicle. That weigh the weight transfer includes some poundage onto the front axle. Adding it behind increases the weight on the rear but also adds to the trailer/tongue weight and decreases the weight on the front, (steering) axle.
SleepyC :moon
