Wiper Wiring
MOOSE
Member
Nov 7, 2003
624
1
2001
22 Cruiser
Hull Identification Number
CD022963D101
MOOSE
I'm installing electric wipers, having ordered them directly from C-Dory, and of course they did not come with any instructions. And, being the electrical idiot that I am, I need some verification on what the purple wires are for. My guess is that they are connected together to enable the self-parking feature if the wipers are wired to the same switch. Since I'm going to wire to separate switches, I assume I do nothing with them.
??? & TX
Al
Al --
I looked for my copy, but can't locate it.
I found the complete installation and wiring instructions on the wiper maker's website. To use the same switch you need a big diode and that's in the instructions. I couldn't get it to work.
The purple wire is a constant hot wire and is connected to the hot side of the switch so the wipers will park. There are two hot wires for sure. Otherwise they just stop in place.
Mine are on separate switches as I often only need one.
Diagram with wire color notes for my 16 Cruiser which may help your installation.
-- Chuck
Al on the Moose, (sounds like a picture I'd like to see)
I have the double wipers on my 16' angler. I'm heading down to try a new kicker on the Denebola :star in the next day or two, so I will take a look at how they are wired. This wiring was done by the factory.
Jon
See the Electrical and Wiring Photos page for the installation instructions for the AFI wipers (4 pages, labeled 1-4 through 4-4, on the last page of the photos).
To answer your question, there are three wires: red, blue and black.
Red is the power to the wiper, when it's on. It is wired to the cold or outlet side of the power switch.
Blue supplies power to the unit after the power switch has been turned off, so that the unit can continue to operate until it "parks" in the proper position. Blue comes off the hot, or inlet, side of the power switch. Blue is therefore always hot.
Both red and blue are fused.
Black is ground.
The foregoing holds true for a single switch installation, with the qualifier that a diode is placed in the red line to the second switch, as indicated.
Thanks for the tips. I didn't realize the mfgs. drawings were in the library. I tried to print them off yesterday from the AFI site, but I think we have an ancient version of Adobe Acrobat, and the text was unintelligible. It looks to me like no diode is required if wiring to separate switches, n'est ce pas?
Al
