Searched by didn't find anything specific.
I'm hooking up a VHF and I-pod ready stereo/CD player (Sony CDX-M60UI) on 'Au Kai.
The Sony wiring shows three power connections:
red=power
orange/white=illumination
yellow="memory"
It says to hook up the red/power to the "ACC" [iginition] so the unit will only power up when the key is in. The yellow/"memory" connection needs a constant 12v power source. The orange/white illumination is obviously if it's installed in a car when the lights are on, the unit illuminates.
My questions:
What do you all recommend for the Sony wiring? The boat is obviously different in that the battery switch will kill ALL power to the boat. Correct? :?
I have two unused "accessory" spots on the original factory panel. (10 amps ea) Can I hook up BOTH the VHF and the Sony to one? That would leave one still empty for a future radar/plotter combo.
I have to go and look to see if the gauge lights are hooked up to the running lights or are always on. IIRC, they are always on.
You can see that my obvious lack of electrical installations has reared it's ugly head yet again.
red=power
yellow="memory"
My questions:
