Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,865
- Reaction score
- 211
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
The boats referred to by James are "shells": Sculls (where a shell is rowed with a person using two oars; usually one and two person) and Sweeps (where each rower has a single oar--usually 4 or 8 rowers). The larger boats have a coxswain who faces forward, and the rowers face aft (pulling mostly with their legs on sliding seats). The aft most sweep (stroke sets the pace and can possibly see danger coming from aft. These boats only have relatively low freeload and the beam is very narrow (11" to 24"). They are capable of about 13 to 14 mph when racing.
The river is narrow, so passing at an acute angle is not possible. I find that when going the same direction I slow down and follow along, unless they are going very slowly. In that case, I get as far away and parallel as I can, and get to a speed which will pass them slowly.
Where going the opposite direction, I slow to a idle just fast enough to control my boat, and again get as close to the bank as possible to minimize the boat wake. I usually slow when I am at least 100 yards from them to minimize the wake--coming directly off the plane to an idle speed.
It seems that when these teams are practicing that they do take frequent breaks to critique and rest. This is a good time to pass slowly. Many teams have a coach boat. The more affluent teams have specially designed light weight catamarans, which make minimal wake at 10 to 15 mph. Others may have an aluminum Jon boat or a Boston Whaler type, some of which will often make considerable wakes at the Sculls speed. However, the narrower square bowed boats can get between rowers for adjustments, safety and relief of crew.
A competitive racing shell can cost as much as a C Dory ($25,000 to $50,000).
