thataway":tnwkvfvh said:
Colby when we successfully got up the Econ, we were with Molly Brown, and had to pull her off, when she took a "mis-step". We are used to going thru shoal water with our lower unit raised up and that was also necessary. After over the sand bars, the Econ is plenty deep almost to Orlando. The second and 3rd times we were not able to get on Harney because of weeds. The opening to the Econ is a bit of a ways past the bridge. We had a drone with us on the second and 3rd trips, plus had downloaded a recent arial / satellite photo of the region, to help plan out the "attack". On the other hand we always enjoy "Deep Creek" and there is plenty of water!
Hi Bob,
I heard about that trip from James. He did say he made a wrong turn...and you pulled him off the bar. We almost didn't make it into the St. John's River on the south side of Lake Harney. Actually, almost didn't make it into Lake Harney. There is a shallow area coming into Lake Harney from the north. There was a traffic cone, and I started out on the west side of it, but grounded the motor even with it trimmed up. So backed up, and tried the other side. I did get past it, but with the depth sounder reading 1.3 under me. Coming back, a fisherman waved me back to the same side I grounded earlier, and said to go around the left side of it. I did make it thru going back, but again, ran the prop thru sand or mud. That was the side that other boats were going past it on. Most on plane, but I did notice one guy before I got there, going thru slow. On the south side of the Lake, I did find the entrance to the St. John's. I was using the track that Ken shared with me from the last time he and James went up the Econ. There are some stakes to stay between on the entrance there. However, I was churning sand coming in from the north, and watched an oncoming fast boat swing out more to the east. (I went back out a little more to the east after the last stake, and still churned up sand.) Going in and out, staying in the marked channel at the most southern stake, even with the engine trimmed all the way up, I was still pushing the engine skag thru the sand/mud. I would probably have stayed off the bottom if I had tilted the main up and just used the kicker... I didn't have any more trouble until I got just past the bridge at the Jolly Roger fish camp and C Lee Boat ramp. I went under the bridge, and then just beyond the first little island, Ken's track went between that island and a little larger island. That's where I drew the yellow line. I tried in several places, but was putting the bottom of the hull hard aground. NO way was I going to pull the boat across by getting out and walking it. So I tried straight ahead, seeing that channel came back out in the one I needed to be in, but got too shallow even with the main trimmed up. Turned around, went back under the bridge, and tried to get in the channel earlier. But as soon as I passed under the bridge again, it was again getting to shallow even with the main trimmed up. Went back the first way one more time to see if I could find a deeper spot in that bar between the islands, with no luck. Beached the boat to do some computer work since I had cell service, and watched a small fishing boat try cutting across that bar on plane. He quickly came to a stop. He trimmed his motor up and then powered thru. But he probably drafted only about 6", and might have weighed 1000 lbs.
Anyway, for next time. The water levels need to be higher. These are the two bridges today on the way down. The first being the Lake Monroe I4 bridge, and the second being the Bridge by Gaters SE of Lake Monroe. Both of these are on the upstream side.
Oh, regarding Deep Creek. We did cruise in a ways. Always so serene and beautiful. Then came back towards the St. John's and anchored in that big cove just a short distance inside Deep Creek. Was a nice night, except around 9p and 10p, when 4 or 5 clowns came in with their airboats! I'm pretty sure at least one of them on the way in took a turn around C-Traveler. I don't understand how they can run as fast as they were in Deep Creek. In Butchers Bend tonight.
