Active member
- Joined
- Nov 7, 2003
- Messages
- 7,976
- Reaction score
- 15
- C Dory Year
- 1984
- C Dory Model
- 27 Cruiser
- Hull Identification Number
- wn something
- Vessel Name
- to be decided later
also when downrigging that deep make sure you use the same weight ball on both sides. I spent a really bad day fishing a round 12 and a flat 10. I was crossing wire all day. i really hated it. I will not go any ligther then 12lbs and perfer 15 lbs in the sound. Dont be shy about speed either. 2.5 to 3.8 mph with 'WITH" the current. Abig mistake that we all make when learning downrigging is wasting time trolling against the curent. troll with it or across it. if you are trolling a slot or rip and get to the end , pick up your gear and run back to the up current side and troll back down agian. dont waste time trolling against a 3mph current for a hour to get back to the top just for 15 mins of trolling with the current. Pick up and run to the start. more time with the current at the right speed and depth, and troll in to the sun when you can.
