12v electric blankets
Robert H. Wilkinson
Active member
Jan 26, 2011
1,284
2
Romakeme IV
Anybody have good results using a 12v blanket or a 110 one through an inverter?
We brought our 110 blanket with us this Sept. When I plugged it into the inverter the light on the one controller started blinking(which I think indicates a problem) and the blanket did not work. The next night when we had shore power we tried it and it worked on one side only. The other side was dead(it had worked previously). My wife also had a small electric throw which worked fine until I tried it in my truck on another inverter. Same thing - it no longer works since plugging it into the inverter.
They are Sunbeam blankets - both were bought at a liquidators for cheap so it is no big loss but I am wondering did the inverter kill them? Are electric blankets and inverters not compatable? Would I be better off getting a 12v one? The 110v matress cover is rated around 100 watts on high so I was thinking on low it would be fairly power conscious.
Thoughts?
Rob
Robert,
I used to have my own truck and hauled meat out of Chicago for a time. I had a 12vdc plug in mattress type warmer. I used to plug it in about and hour before crawling into the bunk and that worked pretty well and held up for years. It had a adjustable dial for different heat settings and a regular cigarette lighter plug. I have no idea what the electrical draw was rated at.
We stay warm in our boat while in the berth without heat. A Travasak with a large comforter on top but do use an Espar D-2 diesel heater on mornings especially when the temp falls below 40 degrees once we crawl out to make coffee.
D.D.
Rob,
I have a hard time trying to understand how an inverter would take out an electric blanket. The blanket itself is just a resistive heating element and the inverter wouldn't affect that. The electronic controls for the blanket may be more sensitive to power variances but it depends on the kind of blanket and inverter. Here's a web page that discusses the use of electric blankets on inverters.
FromTheAboveWebPage":d1tmgjzd said:
ALL heated electric blankets and mattress pads (and heated throws) bought for the United States market will function as well with FULL WAVE inverters as they do with shore power. However most brands will not work consistently with MODIFIED sine wave (MSW) inverters due to the type of control electronics they employ. Some electric blanket controllers have even been known to “fry” when connected to MSW inverters.
There is only one brand of electric blankets, electric mattress pads and electric throws that we have found to consistently test well with MSW inverters. It is the SoftHeat Low Voltage™ line of heated products from Perfect Fit Industries in Charlotte, NC.
As for 12V electric blankets, we have a couple. They work well but most are designed to automatically shut off after 15-30 minutes of use so that you don't drain the batteries. We used them as lap blankets (for the wife) while cruising around and she just hits the reset button as needed. For sleeping, they're useful to pre-warm the bed but not for the full night due to the auto shutoff feature. We've found that with a good blanket, pre-warming the bed worked just fine.
We use a heated mattress pad on 120 or 12v with a small inverter. I draws a bit over 100 watts and has not caused us any trouble over this first year of use. I actually may take it off the boat as we find its effect to be minimal on our comfort level. The wallas 1300 heater is the real hero for us and when at a dock, we do have a very small shore power heater ceiling mounted in the berth to take the chill off up there.
Greg
We have run 110V electric blankets off a pure sine wave inverter (for short timesI), but in the RV, where we have much greater battery capacity. In the boats, even in AK, we always piled on more blankets.
Thanks all for the replies. After going on the website Roger provided the link to I think the problem is my modified sine wave inverters. It says they have been known to fry the controllers on electric blankets. It does say there is one blanket that will work with msw inverters - Soft Heat I think it was called. We do carry ample comforters, blankets, etc. with us but it is nice to pre warm it then shut it off. We found it good to put a heavy comforter under us as well - the vinyl cuddy cushions seem to stay cold all night!
I do have a pure sine wave inverter for my house - Trace sw2512, but at over 90 pounds and $4,000.(when I bought it in 2002) - I think it would be a little bit of overkill for a 20 foot boat!! :lol:
Regards, Rob
rogerbum":1dwx7ewc said:
Rob,
Where can I buy those 12vdc blankets. I think they would be perfect for the cooler weather out here.
You might consider these as an eco friendly, low power alternative.
1. Flannel sheets
2. Fleece PJ's, (pants and sweatshirt)
3. Fuzzy socks
4. Hot water bottle, filled at the marina or with left over hot rinse water stuffed into the sack a while before crawling in.
5. :lol: :lol:
Flannel or fleece sheets seem to alleviate the " cold sheet syndrome" when getting into a cold bed for me. Have some fleece sheets I got at Costco 2 years ago. They're quite luxurious--along with a comforter I'm cozy--don't need a heater at night. Even when boater homing last winter with temps in low 30s was fine. Turned the heater off at bed time--did use a 2nd comforter though. Worst part was getting out of bed in the AM!
It's the potty break at 2AM that gets me!
Was just checking out electric blankets on different websites. They actually have a mattress pad that heats and/or cools! Apparently down to 46deg. F. They were designed for RV's and boats. A bit pricey though at $900.00 for the double size. Touted as using less power and quieter than running an AC unit. Says they use 150 watts on high and about 80 watts average.
Anybody tried or heard of them?
Rob
Is this it?
A lot cheaper than that here.
Ray, I can't seem to re find the website I was on last night but it was similar to the blanket your "here" link took me to. Twice the price though!
Not thinking of getting one myself, but for those in a warmer climate??
