Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,836
- Reaction score
- 192
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
Martin gives a good description--my version is a little different, but the same principle. I use a little longer piece of chain--about 4 feet, and a bow shackle with an extra line attached to it, The chain is thru the pin (one link at each end). I use the main boat to ease back after the chain is around the shank of the anchor--and pull back slowy--don 't put much force on it until I am sure that the chain is down around the shank as far as possible--this is by feel. I do go at 180 degrees of where the boat was riding and the anchor was set. When I am back at 2/1 scope, I then cleat the pulling line down (we still have the anchor rode on the boat) and slowly give pull in reverse. The reason I use the larger boat probably has to do with a small motor on the dinghy (3.5 hp) and my age/back.
The trick is getting the chain down over the shank. I keep the rode tight and even depress the bow a little during the time I am lowering the chain.
As I back the boat up, I keep a little pressure on the pulling line attached to the chain.
I have had to use another trick when caught under a cable on several occasions. That is to bring the anchor up as far as possible--then either diving or using a boat hook, if you can get the anchor and cable as close to the surface, place a piece of rope around the cable--take this line up tight with both ends cleated down. then suddenly drop the anchor; this should allow it to drop free of the cable. Cables are found in many anchorages where logging has taken place.
