Christopher-Robyn
- Joined
- Jan 10, 2008
- Messages
- 80
- Reaction score
- 0
- C Dory Year
- 2008
- C Dory Model
- user_field_choice.c_dory_model_16_Angler
- Hull Identification Number
- CD016709D808
- Vessel Name
- Christopher K.
Does anyone have any experience with installing a Garelick cockpit step (P/N 25022) in a 16' Angler? I'd like to attach the mounting brackets to the vertical side of the bulwark, a couple of inches below the top of the gunwale & just aft of the cabin grab rail. I'm not sure how to get to the back side of the vertical bulwark to attach the mounting nuts & washers after I drill the holes. There is a lower section that appears to be attached to the bulwark with sheet metal screws, but around the edges it looks like it may also be glued in as well. It looks like adhesive, but it may be flotation foam that was pumped in. Will I be opening a can of worms if I remove the screws and try to get the section out? Any thoughts?
Thanks!
Paul K.
Thanks!
Paul K.
