saltspring":1e2eijcn said:My 19 has a Honda 90 on it and a 8hp Yamaha (87 pounds). I do have a perma trim and I find that if I am running at 4,000 4,500 rpm I can trim the motor pretty far up and only have the tabs down one or two clicks. Before the permatrim I found I was messing around with the trim tabs a lot, now I rarely adjust usually just to balance right and left ride.
I find the optimal ride is at about 4,000 rpm which puts me running at about 18-20 MPH. I have not done detailed fuel calculations but it does seem that running a long time over 4,000 RPM uses sharply more fuel.
Nice to see a 19' thread going!!!!
Good notes! Based on my reading of this thread over the past week, I approached trim very differently this weekend. Big differences! I also found that 4000 - 4500 was the point where I was up out of wash and gliding very smoothly. I have the 90 Yamaha and had a little more than 30 gallons of fuel aboard. I noted your thoughts about engine trim... I think that's the one piece I still need to work on. I don't have the permatrim, so sounds like my situation is a bit different?
