1985 C-Dory Angler/ Accessing the Helms Rocker Switches
Tug
Active member
Jun 22, 2007
1,003
6
1985
22 Angler
DOR22241H585
Drifter
I'm am adding a new Chartplotter/Fishfinder and would like to connecting the power cable to the rear of the rocker switches. How do you access the rear portion of the rocker switch to connect the power cable. Thanks.
If you cannot access the switch from the V Bert (back of console, then remove the screws and pull the whole panel. Be sure and use proper fuses and good crimp fittings with marine wire, and heat shrink tubing. I find it easier to put a fuse block behind the console, and then when. you add items, they are easy to hook up.
Bob thanks for the information , i will look at it again and give it another go. Tug.
