In response to Seabran's question reguarding use of Mokai with CD22 decided to start new topic instead of being out of Topic on El and Bill's topic Solar Flares
Steve
Sure regret not taking pictures of our 1st try out on the Snake River ID. Its a very picturesque spot and was a perfect place for starting our learning curve on the Mokai's and our capabilities other than lack of large lake or ocean type waves.
You asked some very good questions will do my best to match the questions with equally good answers.
On the CD 22 we carry it on top stern forward so the rear of the Mokai is as far forward on the cabin roof as possible and up against the radar supports. This allows it to be balanced on the roof before tying down. We support it on the roof with kayak foam supports and secure these and Mokai with straps to radar support and cabin roof hand rails. On the test run we drove 430 miles with 0 problems.
We have very little white river water experience and zero with a kayak but have had a scanoe with small 3 hp motor in extreme conditions quite a few times on Yellowstone Lake which is notorious for extreme conditions and this with only one swamping. Would much prefer the Mokai. I think it would handle the 20 knot winds and 2ft waves and then some, but you would get wet in the process. With one person or two its capable of much faster water up and down than I was expecting. Need more time to determine just how much. We're planning on as much river and lake time as possible before our upcoming Alaska trip.
Its extremely comfortable with one person and very tight with two. Jo-Lee and I have a high tolerance for extreme conditions so our judgement in this area most likely would not match others. We have happily gone well over a 100 miles and 16+ hours in a day several days in a row on a small RIB with only stopping to build fires for warm up and coffee brewing. This with putting on frozen stiff clothing to start the day. We spent a couple enjoyable hours in it together in March and plan on some lengthily trips this summer. With two people its bow heavy and with any wind and waves you are going to get wet quick. I'm 6' 185 lbs and Jo-Lee about 5' 4" and maybe 140 lbs. [I'm in trouble if She reads this] Not much bigger than this is going to work at all with two.
Jo-Lee has a very bad shoulder so can give me very little help in getting the Mokai on and off the boat so I did it all by myself just to see if I could. I'm in fairly good shape for being 59 years young and again found this process much easier than expected. We have twins on the CD22 and I don't think I could do it with a single motor by myself. I cover the twins with a small plastic tarp then use them to slide the Mokai directly from the rear up onto the roof. The twins work as a guide. On land or water this worked well for me. Of course launching is much easier than remounting. It tows so well behind the boat that the plan is to only put it on the boat for trips to and from water. I'm putting roof racks on the pick up camper shell to carry it for local trips and if it works well for the longer ones also.
Next weekend plan on trip to Jackson Lake, Wy in Teton National Park if the ice is off the lake. Normally it wouldn't be, but this year spring is about a month ahead of normal, so hopefully we will have some pictures to make more sense of my ramblings.
Overall the Mokai is absolutely amazing and is the equivalent on water to our 4 wheel ATV on land. Its opening a whole new world of exploration in conjunction with the CD22 that I am in awe of.
Steve
