When the motor is vertical the oil level is right at the high mark. When I put the motor on the boat braket it shows below the low mark because of the angle of the bracket. So I moved the tilt up two notches to make the motor level, but then when I place it on the dingy (achilles LSI 230) the motor is tilted up and the oil level shows high. I'm not worried about dingy performance because we just put around. My concern is damaging the motor. Is it okay to run the motor like this as long as the oil shows in the correct range when vertical? Anyone else experience this.
