2000 honda 8 hp
UncleRichie
I have a honda 8 hp made in 2000 I just checked it and have water in the oil anyone have any ideas where it could be coming from . I have alwise flushed it after each use in the salt ,it runs fine no smoke or water vapor coming out the exaust . Anyone have any ideas have looked on line and not found a lot.
Richard
It's pretty common, caused by the engines running too cold and getting condensation buildup from combustion. The cure is a thermostat that opens at a higher temp. Mine did the same thing, it too is around the same vintage.
Your thermostat could also be stuck open.
