For sale 2005 22 ft C-Dory.
$38,500
The C-dore' is for sale
She was fully out fitted with the following by E-Q Marine
1. Honda 90 , new impeller,spark plugs, T-stats,fuel filter, + Nissan 9.9 kicker carburetor rebuilt by shop,with tie bar connection to main. Mounted on kicker bracket. this kicker is electric and hand start with a alternator This allows you to pull start he kicker and charge dead batteries .
This will save the trip if a left a light is left on overnight. The main can also be pull started.
1.1 Perma Trim
2. Twin Batteries (new batteries in 2010)
2.1 Guest on board hard wired battery charger
3. Three way battery switch
4. Raymarine C-80 navigation system with dm300 fish finder, Radar, Auto pilot and GPS. Also the North West map card. Autopilot has just been serviced by Raymarine
5. Two Scotty swivel bases with wired in plugs under rail.
6. Full camper canvas enclosure.
7. High top cabin special order
7.1 New Wallas stove heater. We just updated it with the newest model two years ago
8. Radar arch ( I have added 6 rod holders to the arch for better rod storage) Radar, vhf and gps antennas are all mounted on the arch.
9. 6 gallon water tank in the bow with electric water pump at the sink
10. Center opening window.
10.1 Electric dual wipers
11. Forward facing seat with storage under floor. This seat will face in either direction.
12. Installed the porta potty under the port side aft seat where the water tank was.
13. Hydraulic steering with auto pilot. I have also added a wireless remote to the auto pilot.Replaced the helm seals and replaced the steering ram by Baystar.
14 swim step with ladder
15 trim tabs with indicator at dash.
16. Twin bulge pumps.
And all the other stuff that a c-dory comes with. Since then we have added or up graded the following.
1. I have added a shelf in the kitchen cabinet and relocated the wallas fuel further back in the cabinet.
2. Added a vent for the fresh air inlet for the wallas
3. Over head mounting of the Garmin VHF (this is a new unit this year that will receive and broadcast gps DSC info. This allows you to see DSC info and positions of other boats right on the Raymarine C-80
4. Am/fm, CD, iPod, USB port capable radio with two speakers
4.1 1000 watt inverter
6. We have fully carpeted and insulated the sleeping berth. One of the best things we have done. Stays a lot warmer.
6.1 Installed Hypervent under the mattress this stopped all moisture in the cabin and under the the mattress, this stuff is great
7. I installed three huge storage hatches in the v-berth. The factory removed the foam and installed three small hatches when they repaired a common leak in the bow strip, I up graded to three over size hatches.
You can drop a full size duffel bag thru the hatch and fit two of them in each hatch. Lots of storage
7.1 Had a cushion made so that when the table is lowered it can be a couch we use this position most of the time.
8. A full floor. My boat is the only 2005 that has the raised molded fiberglass floor. I had it installed by lake union sea ray. I bought the floor from the factory and had it installed.
This is a great improvement over the original floor and I see why the factory switched to this system on all the newer boats.
9 when the floor was done the fuel tanks were replaced with the bigger ones.
9.1 Racor water fuel separator .
10. Fish Box. We had a custom fish box installed. Again I had the good folks at lake union sea ray install this for me. It is in the splash well. It will hold 40 crab or four twenty pound salmon, or a hell of a lot of shrimp.
My favorite upgrade. Even if you do not fish it makes for a great place to get the fenders out of the way. Provides plenty of storage and an extra place to sit and visit. Also makes it easier to get in and out of the boat.
12. Upgraded rear hatch covers. As we all know the factory hatches leak. So I, like many others, replaced the hatches with better ones that don’t teak at all. Love them.
13. New Lewmar windlass with 25 ft of chain and 150 ft of rode. I installed a breaker and control switch for the windlass at the dash.
14. Wireless remote spot light. I had a stainless steel plate welded to the bow rail and installed a spot light with the wires running thru the rail to the v-berth.
Great for finding crab and mooring buoys at the end of the day. Anytime you stay out a little too late you will love this light. Check your position at night when the wind is blowing. Peace of mind
15. Custom made window coverings and privacy shades for the camper back. No more people looking in while you are sleeping or eating. This full encloses the aft deck for privacy.
16. Storage self under table. If fact there is storage everywhere.. I also moved the floor of the storage above the water tank under the back seat. This also increased the storage over stock.
17. The table is larger than stock. I made a new one when I replaced the poor table stays with a better design.
18 I raised the step and storage locker under the pilots feet. This allows my feet of sit flat on the surface and it allows or twice the storage space over stock.
There are three remotes. One for the spot light, one for the auto pilot and one for the radio
The King bunk trailer is tandem axle with new Titan calipers, pads and rotors,new tires Les Schwab, and spare tire and wheel
Comes with all the lines,fenders,straps,safety gear.
Turn key ready
I would consider partial trade for a 16 footer.
Steve
sabadd03@live.com
http://www.c-brats.com/modules.php?set_ ... php&page=1[/url]
$38,500
1.1 Perma Trim
Turn key ready
Steve
sabadd03@live.com
