Major Tom
- Joined
- Jul 4, 2016
- Messages
- 80
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 22 Cruiser
Hi, I need to get a spare prop, and while I'm at it I thought I might experiment with a slightly different pitch or diameter. I've read several posts on this subject, but could use some advice specific to my situation.
I just got this boat, changed oil, new plugs (the recommend NKGs) and took her out twice. The previous owner painted the prop blades (not the hub) with bottom paint, and she has decent bottom paint but needs a little touching up. I ran her light, with just 20 gal of gas total, no gear, 125' of chain rode in the bow, and 350 lbs of skipper and first mate. Prop is stock Honda 3 blade 13.5 x15 aluminum.
WOT I get 5200 rpm, 28 mph gps over ground, on flat water.
I'm also using 93 oct non-ethanol gas, Techron Fuel sytem cleaner, and a touch of Stabil for good measure (about 50% of maintenance dose). After I run a few more gallons of that through her I'll use some Seafoam and see how that does. She ran smooth through the entire range, but idles a bit low, around 650 rpm.
Those results are OK, but from what others have posted and the specs on boat test I thought I'd get around 5500-5800 and top out at 30-32 mph. I've used Techron on other engines, and I usually notice a slight drop in performance until I put fresh gas in her. So maybe it's that?
My main concern isn't eeking out a couple more mph or mpg, (although a bit more top end speed would be nice ) but I do want to ensure that everything is tuned as it should be, and that the motor and carbs are clean. I'm waiting for my outboard mechanic to look her over so that's why I'm posting this. (he's so busy now I can barely get him to return calls!) I haven't added a kicker yet either. Not ready to have carbs cleaned, too many other mods and rigging to do now, and my mechanic is so backed up anyway...will probably do that next spring.
Any suggestions? I thought about trying a 14 x15 or 14.5 x 15 if I can find it. But that would lower my rpms, and I don't think I'd get any more top end speed. So maybe i should go the other way and try a bit less pitch, like a 13.5 x 14? BTW, definitely aluminum... I plan on boating in a lot of unfamiliar waters
Thanks!
Thanks!
