ggray
- Joined
- Jun 3, 2020
- Messages
- 63
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 22 Cruiser
- Vessel Name
- Red Top
I ignored the water under the cockpit last summer, but want to do something about it now. The bilge pump just doesn't seem to be located where it can pump all the water out.
I've seen the suggestion to install a pump below the aft deck/cockpit sole, but before I take this somewhat complicated step, I wonder if caulking the joint at the aft of the cockpit sole, and plugging (fiberglassing) the gaps fore and aft in the "walls" either side of the (for the lack of a better name) bilge compartment would contain all "cockpit" water to the area the pump can evacuate. I'm thinking, how else can water get under the cockpit sole than by this route? I have a picture of this area that I'm having trouble inserting, but I figure you know what it looks like
Is this a reasonable solution? Is there anything else beside a pump under the sole? I'm curious why the factory didn't address bilge water differently.
Even so, I think I would install a small deckplate...maybe a plastic water fill fitting... in the sole that I could remove water that's under there now, and what little might leak around the battery hatch seals.
