Will-C
- Joined
- Aug 21, 2007
- Messages
- 2,476
- Reaction score
- 2
- C Dory Year
- 2008
- C Dory Model
- 23 Venture
- Hull Identification Number
- CD023007A808
- Vessel Name
- Will-C
Hello,
In looking at the Fluid Marine information about the 23' Venture the weight shows 3020 pounds. They recommend a 115hp or twin 70's for power. Yet the performance chart for the 23' Venture shows twin 50's; seems to be a bit of a conflict.
It would seem that weighing a 1000 pounds more than a 22' Cruiser the 23' would be a tad under powered with a 115hp. Loaded with four people and the usual amount of gear running in an inlet from the ocean is not a good spot to be under powered. I wondered if the foam composite rather than the balsa core is what makes the 23' Venture so much heavier than a 22'cruiser. I know the hull has a little deeper v but they don't seem that much different in size. I guess the shore power and the refridge count for some of it. All of the weights listed are from the new C-Dory website and are dry no motors etc. When you consider a 25' cruiser's weight is listed at 3602 and is rated at 200hp the 115 power recommendation seems a little light given that there is only 600 pounds difference between a 23' and a 25'. Your thoughts?
D.D.
D.D.
