A
Anonymous
Guest
Just a few things...
It's THE best winter engine! great starts, better for slow-cruise in choppy water (typical winter running) and not even a trace of condensation in the oil!
Definitely better mpg for all slow cruising!
It obviously makes a far better trolling engine than a larger engine it replaced, and I think it generally gets about 20% better (averaged figure on my all around use) fuel economy.
(on long trips with heavy loads trying to run fast, it might be getting the same economy as the F-115 it replaced)
Prop: Still experimenting, but for any Classic 22-foot C-D loaded lite to moderate, don't go over 13 pitch with 3 or 4 blade prop. 11 to 12 pitch is ideal.
Mercury 11P aluminum: Great prop but ventilates too much in rough water when light or too much weight-forward. The 11P Merc' Aluminum prop achieves at WOT: 24 mph and reach the maximum rpm with the boat packed for a long trip.
By going with a mere 70hp main engine, ideally you should have a prop for heavy loads and one for just taking day trips... one of only two dislikes by the down-size.
For the Classic 22 C-D at least, this light engine could work against you in trailing seas. It does ventilate more than the heavy 115 ever did with it's 18P prop. Just make sure you don't over-stuff the cabin (people and gear in big-water-running) and keep as much weight in back as possible.
I did find a favorite prop: 4 blade SS Solas 13P, but only after I bent the blades-down a notch! You can do this quite easily!
I had to, after chopping through some huge bulb kelp fields wide open and later found the blades were got tweaked. :|
I had really great performance with the "Merc' Vengeance" 12P SS (when it was new) but after hitting a sand bar, the prop could no longer perform satisfactory --too much venting even after I hammered the cup back into it.
Best top speed is 29 mph light, with the 4B SS Solas. The Merc' 12P was just as fast but lacks 4-blade-smoothness and always ventilated more.
(the 4 blade also gives a better ride due to stern-lift)
Next prop will be the Solas SS 3 blade
4 blade only goes down to 13 pitch. Unless your just making day trips and light that way, I recommend a thin SS prop with plenty of cup in a 3 blade SS 12P. Solas props are thiner and a lot lighter than the Merc props i tried...
