If you're talking about a 70hp Suzuki, it is sufficient and would work just fine but the way we load the boat and for our use, I'd go for a 90 hp or 115 hp Suzuki.
Our first year (2005), not knowing much about boats or boating, we went with the factory recommendation for the 70hp Suzuki. It's a nice engine but we were underpropped. Instead of taking the bull by the horns, we waited for the factory to give us a replacement. It took most of the summer boating season. Hence, we couldn't get up to the recommended rpms and the boat lugged something terrible. It felt very underpowered and we could barely break 18 knots WOT. When we finally replaced the prop, it was like night and day. The boat ran great, like the new boat as it should have all boating season. We were able to make the maximum rpms and hit around 24 knots at WOT. I kick myself now for not changing the prop sooner.
However, despite all that, we decided we wanted that extra power and piece of mind knowing we have the power to get out of trouble if needed and went up to the 90hp Suzuki. We haven't looked back since, we love it and it's a great motor. If we were to do it all over again, we'd choose the 90 hp over the 70 hp. Like I said, there's nothing at all wrong with the 70, as long as you've got it propped correctly. The 70hp Suzuki is a smaller engine, the 90hp is the detuned version of the 115hp Suzi. It is heavier, but with trim tabs and a Permatrim, the boat handles better than just fine. It works out great.
I know that the Honda 75hp and 90hp are the same engines, the 75hp being detuned. Many people opt for the Honda 75hp and it works out just fine for them. It all depends on how you want to use your boat. For us, we wanted the bigger engine with greater torque. Good luck in your search for info.
Peter
C-Dancer
