I installed a Sea View 16” radar mount and fold over Light Bar to replace my radar mount (which broke off with the radar attached) and to clear the rooftop AC. Bob, good call without even a label!
https://www.amazon.com/SEAVIEW-LTB-90-L ... 8090&psc=1
Like mine, the above provides for loosening 4 bolts to fold over. Sea View offers a $150 quick release option (which sounds like the kind of thing your PO would pay for, and I bet you have it, not a rivet, a quick release lock lever mechanism to rotate and lock).
https://www.hodgesmarine.com/sealtb-90- ... ght-b.html
I have the Perko 1197 incandescent, you have the LED, but the wiring is the same. Both come with a 7 foot lead from the bulb down into the light bar to connect to the boat wiring, most likely above the shelf under the roof bolts for the radar mount. Look for a black or yellow (DC neg) and a gray wire (all nav lights) coming out of the Seaview radar mount (gray is also used for the tach, but that would be under the helm console, not up here). The gray wire for the side port nav light is under the ceiling mouse fur at the aft section of the berth; the port side nav light goes direct into the under console 12v hub center.
Here’s an old but simple boat wiring color guide...since then the approved color for DC negative changed from black to yellow (except in Yamaha world, where yellow is 12V DC POSITIVE ignition on, a horrid exception that I discovered in the most expensive way).
https://www.boatingmag.com/abyc-color-c ... at-wiring/
There are multiple legal ways to wire a boat and stay within standards, so there WILL be differences in the hive advice. Bob referred to a ‘negative bus bar’ under his helm, and I don’t have one but have the ‘fuse block’ I pictured in a prior post. If you have the white version of the Blue Seas 30A switch panel (prior post), it will lead to a Blue Seas fuse block since most circuits require protection of 5-15 amps, not 30. Each fuse is a different color depending on amp rating at which it is designed to blow ie burn through and cut off that circuit. To expand on my prior post regarding Blue Seas “Easy ID” fuses...they only show a LED if the circuit protection has BLOWN, not if it is operating properly.
Find the switch which controls your nav lights. We hope you can see wires from it (gray and perhaps dark blue, which will turn on your instrument lights when you turn on your night running lights as above site) to your fuse block. On the fuse block, look for any gray or blue wire leading into it. That is the circuit you’re looking for. The fuse may be red (10A) but it sure as hell won’t be green (30A) for nav lights. Whatever the color, replace it with a genuine Blue Seas fuse (see my Amazon site for the EZ ID fuses). Sub another lower rated fuse to check if needed quickly.
Does the anchor light come on? If not…
On the fuse block, all positive wires enter the side terminals to enter the fuses, then all circuits exit via the black or yellow wires at the top. Touch your multimeter red probe to the side screw and the black probe to the top, DC voltage should be 13.1 or so on shore power, 12.5 or so off. A decent ‘auto ranging’ volt meter will show varying numbers on a dead circuit so be sure the scale is DC VOLTS and not DC MV millivolts (a dead circuit).
If you have over 12V DC there, then next to check is the gray and black wire leading up to the potted LED in the light. That possible villain is the connection above the shelf between the 7 foot Perko lead and your boat wiring. Cut and strip those wires and crimp on a new connector. You need both these and genuine Ancor butt connectors: (Genuine Ancor is $62).
https://www.amazon.com/Haisstronica-Cri ... s9dHJ1ZQ==
https://www.amazon.com/Stripper-Electri ... 69&sr=8-16
After replacing this crimp, does the anchor light come on?
If you have 12VDC at that connection, but the white anchor light still does not come on, that LED fixture is not fixable. The little black rubber stopper just under the light is an alignment stopper that you can pull out, cut the wires and pull it out. Replace it with a Perko 1197 much cheaper (yes it’s incandescent, but it’s rated for 3 NM not 2, uses almost no power and is under $90 all in).
Anchoring out in a TomCat instead of going to a nice marina is like driving your Mercedes SL550 to a Motel Six to “save money.” (Damn, I’m gonna take a lotta flak for THAT!).
While on the boat at the fold over light bar, call Sea View tech support for how to raise and lower your light bar.
Seaview Systems, Inc
7275 Joy Rd Ste A, Dexter, MI 48130
Phone: +1 734 426 8978
Email:
info@seaviewsystems.com
They were very helpful to me.
I am STILL optimistic that you can get this light working for under a Boat Unit!
I think we all appreciate your sense of humor as you go through all this!
Cheers!
