matt_unique
- Joined
- Feb 27, 2007
- Messages
- 1,881
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 255 Tomcat
- Vessel Name
- Napoleon
This kind of thing drives me nuts and is why I did all my installations myself. Unreal...
Sunbeam":21bz3e1s said:island park":21bz3e1s said:I am curious, do any of the dealers oversize drill and then fill with epoxy when outfitting these cored boats?
Matt Gurnsey":3e7tmf30 said:*The synthetic core material on the transom is not like the foam material that is used to add floatation or fill voids, and will not absorb moisture. Applying a good sealant should prevent water intrusion.
*I'm not sure that you can drive a screw into the foam material without a pilot hole. So drilling the holes too short could be a problem as well. In that regard, I would probably just use a longer screw if you feel the void needs to be filled along with a good sealant.
Finally- boats are made by human beings, with all the flaws and issues they have. Line workers at what may be a struggling company may not have the incentive, or desire to be perfect. Get it built and out the door are often the mandate from on high. Hopefully there is the supervision in place to encourage best practices. I doubt that the factory in this case will view this as a manufacturing defect and pay to have the holes underdrilled and epoxy filled.
Just some thoughts from the business side.
