Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,108
- Reaction score
- 78
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
While at my brothers in the PNW, I was complaining about the ride of my F150 when towing over rough roads. (Too many of our national highways...) I had earlier installed the Timbren springs, which are just hollow rubber cylinders that replace the original axle bumper stops on the frame. With my tongue weight of 620 lbs, for the most part, they were pretty much in full contact with the axle, and on rough roads, it was like constant chop in the boat!
I still do not believe in putting a weight distribution hitch on a boat trailer. I don't think the single pole tongue is built for it, and it's not only placing more stress on the trailer tongue, but also adding some weight to the trailer's axles, along with the tow vehicle's front axle. Not to mention the additional weight of the WDH ball mount and spring bars.
My brother suggested I should get air bags. I had considered air bags much earlier, but the cost was rather expensive. Looking again, the cost doesn't seem so bad. However I came across another system. Roadmaster's Active Suspension Custom Leaf Spring Enhancement Kit. RAS. Air bags are prone to leakage at some point and require an onboard air compressor, or access to air to adjust. The RAS is a coil spring that works with the vehicle's original springs. I purchased and installed the heavy duty model for my F150. (The regular model was good for up to 600 lbs tongue weight, and the heavy duty model for over that weight.) The RAS does not increase the vehicles payload or weight ratings, but rather provides more "lift" mechanically. Using the setting for 40% additional load carrying, I had a rear end lift of 2.5". I can live with that, and I didn't notice any difference in the ride while not towing. Hooking up the trailer, I still had about a 2.5" squat as I did before, but now I'm back at my original height and still riding on the springs rather than on the Timbren hollow rubber cylinder. Driving a short distance to our local lake today, I noticed I still have a little "bounce" on heaved roads, but the ride is more comfortable. For the most part, so far I'm satisfied with the improved ride.
Just wanted to share this in case any one else has thought about adding air bags or some other suspension enhancement.
