Amateur radio suggestions
pcg
Member
Aug 31, 2018
455
13
1999
22 Cruiser
Hull Identification Number
DOR22866J999
This post is addressed to ham radio operators. I have a current extra class amateur radio license, but haven't been active for decades, have no radio gear, and am no longer plugged into the ham radio community. I'm looking for suggestions for what amateur radio setup would be useful on a C-Dory. I don't anticipate using it for casual chatter, but I can see it as a benefit in an emergency as an alternative to VHF. Are there other benefits as well? What about power draw (want more than QRP), antennas, tuners, ground plane, etc.? I'd like to have CW cand SSB capability, but I've heard there are newer digital modes available as well? What do you suggest? I've looked into 2M repeater operation, but anticipated use will be in the Inside Passage where I suspect not many repeaters are available.
It sounds like you might be happy with something like the Yeasu FT-991a all band, all mode transceiver. Without providing specific ham radio goals, this radio can pretty much do it all, in a fairly compact and affordable package. VHF, UHF, HF frequencies and any modes, cw, am, fm, SSB, and digital modes. Given a boat/marine environment, vertical antennas would be a practical choice
The problem with vertical HF/VHF antennas mounted on a C-Dory is the lack of a ground plane. I don't know what the solution to that is. Any suggestions, anyone? Personally, I gave up on it and rely on inReach instead. Klaus, VE7KDU
I’ve been wondering about that and curious to hear what people do. I have an inReach and relied upon it once for communication in an extreme situation. It definitely has its place, but it’s awkward to communicate with text.
I have used ham radio aboard boats for over 40 years. The areas were from The S. Pacific, New Zealand/ Australia, the Med, the Baltic, the entire Caribbean, Mexico and Central America, to the Maine Canadian border, and from the top of the World Highway (via RV, but same rig and antennas) in Alaska. I have lost track of the modifiers used for my call sign. For the C Dory any one of the big three's all HF/UHF//VHF transcievers are good. (Icom, Kenwood, and Yeasu) I have gone with 100 to 150 watts SSB output, but you can always dial it down when necessary and proper.
The ground plane is an issue. My best suggestion is to use 1 to 2" wide copper foil for the ground. I then have worked several different ways to the in the hull or in contact with the water grounds. I have used copper screen, soldered to the copper foil, and then a single layer of light deck fiberglass cloth bedded with epoxy to protect it. This should be as close to the radio as possible. I have also used Dynaplates or outside solid copper plates 1/4" thick and bonded directly to the hull. The copper foil is soldered to several bronze bolts which hold the plate in place. I have also tied the bow railing, and then run foil under one side of the boat above the hull to deck joint, inside the cabin and tied that in. All of these work well.
For Antennas, I have used the Ham Sticks for HF-SSB--now carried by MFJ. Select the bands you want. I would go with 75 m, 40m, 20 and 10m. I have used the MFJ-347, mount on one of the hand rails, or the radar arch. There are plenty of base loaded VHF/UHF dual band antennas. Choose one which is all ss and the coil is well weather protected. I tried Hustlers way back, but there is a lot of pot metal in their construction and they will corrode. There are some all band, and I have forgotten the name of an Australian antenna which had plug ins coils at the bottom. (I felt danger of corrosion there)
The Port Ludlow Yacht Club runs the Northwest Boaters net : 3.865 MHz (Lower Sideband) daily at 0830 Pacific Time (or 0900Z/1530 UTC depending on the season) This net tracks boaters from Calif. tothe Upper Alaska. (I have checked in from as far as Point Conception, CA to Icy Straits AK. I would definately suggest monitoring to start with. They have a limited PM net also. The propogation was not as good then, and I rarely used it. There are regulars who live on Vancouver Island, in the Mainland part of BC, and SE AK. There are a number of boating nets, aI nd I'll let you look that up, since times and frequencies change ofen.
I did have a 600 watt 12 volt linlear amp, but did not use it on the C Dory. You may want to get a manual MFJ tuner. If you are using the whips, most transcievers work fine with the "Ham Sticks". I did notice that there are "shark" antennas on Amazon, with the same frequency bands. I don't know anything about these. There is an antenna which has plug ins for base loading on different frequencies, and I believe is made in Australia, but the name escapes me. For CB you could use a separate whip, or use a 10 meter "ham Stick" and by moving the whip, get it tuned close enough for all of the CB channels. I like to keep my HF antannas at least 3 feet from the ship's VHF radio antenna.
I have done a number of experiments at sea with co-operative land based hams, to test various antennas. On our Cal 46 (which we cruised AK with) I had the Ham Sticks on a tri mount--3 bands on one mount. Which was about 10 feet off the deck on the rear radar arch. I had a shakesphere 23' Marine HF antennna base mounted and a stand off to the radar arch, an isolated back stay, and an all band dipole, either as an inverted V or sloper. I did find out that the boat's riging acted as a radiator. The best was the dipole, sloper. The "worse" was the insilated. back stay, with an auto tuner (SEA, with a SEA SSBHF 223, which had been modified to transmit on the ham bands. For the ham bands I used what is the equivalant of the Kenwood TS-850S HF. I had a MFJ manual tuner similar to the 948. I had switching for various antennas, and I could use the SEA autotuner or the manual MFJ tuner or straight to the selected antenna.
There are also a number of VHF/UHF repeaters, and I have used these a number of times. These come and go, but there are several good resources on the internet. I met some fantastic people on 2 meters via those repeaters. Our favorite Halibut recepie came from a 2 meter conversation and eventually an invite to dinner and the Halibut recipie.
Thank you Bob. This is great information! I am still not clear on what approach to use for a ground plane, but I have a couple months to mull this over. My inclination is to install some sort of radial counterpoise on the ceiling of the cabin, and then carefully bond it to a Yaesu ATAS-120A mounted on the radar arch. The challenge will be how to arrange and affix all the radials I need for the HF bands onto the ceiling. I'm interested in hearing your reaction to this plan...
I am concerned about the Atlas 120A because of the open verible tuning coil and contacts, proper motor function. That sort of thing and salt water, even fresh water, can be a major issue with corrosion and failure to properly tune.
One other trick I used on the Tom Cat (and the cal 46 where I did most of my antenna tests was to make up Ham Stick dipoles for the 75m band, 40 meter and 20 meter bands. There is an adaptor which works well for the dipole of stick/whips. The one I used was slightly different than below, but you will get the idea.
Intellitron AA-1602:​
Type in "Dipole mount for HamSticks in your browser. You shoud come up with a bunch of illustrations and discussion.
On the 38' sailboat we built I put in copper screen and then a single layer of light deck cloth (fiberglass) and epoxy. Run the copper foil from radio to that mesh--it could be done under the cabin roof, but it may not be all that easy to lay that mesh up overhead. When using the copper screen mesh, the more the better. We put in 8 x 8 feet started from the transom forward. Real good heavy copper screen is not cheap. I would go for the $100, vs the $24 screen.
